Knowledge Base Article
Timing-Related Warning Messages for QDR II and QDR II SRAM Controller with UniPHY and RLDRAM II Controller with UniPHY When Sharing PLLs on Stratix V Devices
Description
When instantiating a design in PLL/DLL slave mode on a Stratix V device, the TimeQuest Timing Analyzer may display warning messages similar to the following:
Warning: Ignored filter at slave_report_timing_core.tcl(176): slave_inst0|controller_phy_inst|memphy_top_inst|umemphy|uio_pads| dq_ddio[1].ubidir_dq_dqs|altdq_dqs2_inst|thechain|clkin
could not be matched with a keeper or register or port or pin or
cell or net
Warning: Command get_path failed.Resolution
This issue has no workaround. The warning messages can be safely ignored; however, do not rely on the accuracy of the resulting timing analysis.
Updated 2 months ago
