Knowledge Base Article
Timing Constraints in Auto-Generated JESD204B SDC File Causes Timing Violation for Non-JESD IPs.
Description
The set_max_delay constraint in the auto-generated JESD204B SDC file that constrains the timing between the PHY and JESD204B data path are non-JESD specific.
For example:
set_max_delay -from [get_keepers {*inst_sv_hssi_8g_rx_pcs|syncdatain*}] 8.000ns
set_max_delay -to [get_keepers {*inst_sv_hssi_8g_tx_pcs|syncdatain*}] 8.000ns
This constraint may limit the timing requirement of other IP cores and cause invalid timing violation.
Resolution
Download and run the available patches:
Quartus II 14.1 Patch 0.28
Quartus II 14.0 Patch 0.36
Updated 1 month ago
