Knowledge Base Article
The Hard IP for PCI Express Qsys Example Design Reconfiguration Driver Has Unconnected cal_busy_in Output Signal
Description
Altera provides design examples available in the Quartus Prime or Quartus II installation directories. The Avalon Streaming (Avalon-ST) Qsys example designs include the Transceiver Reconfiguration Controller and the Altera PCIe Reconfig Driver. The cal_busy_in output of the Altera PCIe Reconfig Driver module is unconnected. This signal must be connected for transceiver reconfiguration to work correctly. It is not available in the top-level components of the Qsys system.
Resolution
Because the cal_busy_in output is not available as a top-level signal, you must connect this signal in the RTL.
Updated 1 month ago
Version 2.0
