Knowledge Base Article
The error message displayed in the FIFO MegaWizard Plug-In Manager when you select the SCFIFO megafunction and set depth to a lower value than usedw[] does not show the correct depth.
Description
In the FIFO MegaWizard Plug-In Manager, if you select the SCFIFO megafunction and set depth to a lower value than usedw[], the error message displayed does not show the correct depth. Instead, the error message displays (%1) as the depth value.
Resolution
If you do not know the depth value of the FIFO, set depth to 1, and then check the depth value. You can now set the value of depth or usedw[] so that depth is greater than or equal to usedw[].
Updated 2 months ago
