Knowledge Base Article
The C2H Compiler Regenerates an Accelerator Unnecessarily
Description
The C2H Compiler might regenerate an accelerator even when the accelerated function is unchanged. This problem can result from changes to files included by the C file containing the accelerated function. The C2H Compiler fails to check that the generated hardware description language (HDL) matches the previously generated HDL causing the system to be regenerated.
Resolution
To avoid this issue move the accelerator-specific information from the include file to a separate include file. This Workaround prevents regeneration of the system when the HDL is unchanged.
Updated 1 month ago
Version 2.0
