Knowledge Base Article
The ALT2GXB MegaWizard Plug-In Manager incorrectly sets the XAUI and CPRI protocols for Stratix II GX
Description
In the ALT2GXB MegaWizard Plug-In Manager, on the General page of the Parameter Settings tab, if you attempt to change What protocol will you be using from Basic to XAUI, the MegaWizard Plug-In Manager incorrectly selects CPRI. If you then attempt to change the setting from CPRI to XAUI, the MegaWizard Plug-In Manager closes.
Resolution
To successfully select the XAUI protocol:
  1. In the Which protocol with you be using box, select XAUI. The CPRI protocol is incorrectly displayed.
  2. In the Which protocol will you be using? box, select Basic. The Basic protocol is displayed.
  3. In the Which protocol will you be using? box, select XAUI. The XAUI protocol is now correctly selected.
Updated 2 months ago
Version 2.0
