Knowledge Base Article
Tcl error: ERROR: Argument <clk_object> is a collection with more than one object. Specify a collection with one object. while executing "get_clock_info -period [get_clocks [lindex $fclk_setting_name 0]]
Description
For Intel® Arria® 10 and Intel® Cyclone® 10 GX devices, when using LVDS SERDES Intel FPGA IP with External PLL configuration in Intel® Quartus® Prime Pro Edition software, you may find the below error during timing analysis while executing “Report RSKM.”
Tcl error: ERROR: Argument is a collection with more than one object. Specify a collection with one object. while executing "get_clock_info -period get_clocks [index $fclk_setting_name 0]]
Resolution
To avoid this error, add the below command in the sdc file.
derive_pll_clocks -create_base_clocks
This information has been added to the LVDS SERDES Intel® FPGA IP User Guide: Intel® Arria® 10 and Intel® Cyclone® 10 GX Devices chapter Timing Analysis when Using PLL Core Clocks
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
