Knowledge Base Article
Synchronizing aclr with rdclk and wrclk Causes a Recovery Timing Violation in the DCFIFO IP that Connects to MLAB
Description
If your design uses MLAB as RAM block type and you select the add circuit to synchronize aclr with wr/rdclk option in the Dual Clock FIFO (DCFIFO) IP Parameter Editor GUI, the read clock domain-synchronized aclr signal erroneously connects to the top-level aclr signal, instead of connecting to the MLAB\'s clr signal.
This issue affects the Quartus® Prime Standard Edition software and the Quartus Prime Pro Edition software.
Resolution
Instead of selecting the add circuit to synchronize aclr with wr/rdclk optioni n the DCFIFO IP Parameter Editor GUI, create your own reset synchronizer.
Updated 2 months ago
Version 2.0
