Knowledge Base Article
Stratix V Avalon-MM Hard IP for PCI Express IP Core Signal Change when Multiple Packets Per Cycle Enabled
Description
In version 12.0 of the Quartus II software, if you enable Multiple
packets per cycle in the Stratix V Hard IP for PCI Express
IP Core GUI, the following top-level ports change from one-bit to
two-bits: rx_st_valid, rx_st_err, tx_st_valid,
and tx_st_err. Bit 1 of each two-bit vector
applies to the upper two qwords of data. Bit 0 of each vector applies
to the lower two qwords of data. The Stratix V Hard IP
for PCI Express User Guide defines these ports as one
bit.
Resolution
This issue is fixed in version 12.0 SP1 of the Quartus II software..
Updated 3 months ago
