Knowledge Base Article
Square Root Error in Floating Point Custom Instruction 2
Description
When you implement the Nios II processor with the floating point custom instruction 2 component, the component might produce an incorrect result when computing the square root with custom instruction 251, fsqrts. This error can occur when the expected result is close to 1.0.
Resolution
No workaround is available at this time.
Updated 2 months ago
Version 2.0
