Knowledge Base Article
spl_nand.c:36: undefined reference to `nand_init'
Description
Due to a problem in the SoC EDS version 14.0, you may see the compile error below when using bsp-editor to generate preloader to support booting from NAND flash, :
common/spl/libspl.o: In function `spl_nand_load_image':
...\software\spl_bsp\uboot-socfpga\common\spl/spl_nand.c:36: undefined reference to `nand_init'
...\software\spl_bsp\uboot-socfpga\common\spl/spl_nand.c:94: undefined reference to `nand_spl_load_image'
...\software\spl_bsp\uboot-socfpga\common\spl/spl_nand.c:97: undefined reference to `nand_spl_load_image'
...\software\spl_bsp\uboot-socfpga\common\spl/spl_nand.c:99: undefined reference to `nand_deselect'
Makefile:178: recipe for target '.../software/spl_bsp/uboot-socfpga/spl/u-boot-spl' failed
make[2]: *** [.../software/spl_bsp/uboot-socfpga/spl/u-boot-spl] Error 1
make[2]: Leaving directory '.../software/spl_bsp/uboot-socfpga/spl'
Makefile:612: recipe for target 'spl/u-boot-spl.bin' failed
make[1]: *** [spl/u-boot-spl.bin] Error 2
make[1]: Leaving directory '.../software/spl_bsp/uboot-socfpga'
make: *** [uboot-socfpga/spl/u-boot-spl.bin] Error 2
Resolution
To workaround this problem:
- Go to uboot-socfpga/include/configs/socfpga_common.h
- Modify \'#undef CONFIG_NAND_DENALI\' as \'#define CONFIG_NAND_DENALI\'
This problem is scheduled to be fixed in a future release of SoC EDS.
