Knowledge Base Article
Spectra-Q Timing Analyzer Might Apply TimeQuest Deration Incorrectly to Designs with the set_timing_derate Assignments Targeting Blocks with Minimum Period or Pulse Width Limits
Description
For Arria® 10 and Cyclone® 10 designs, If you apply the set_timing_derate Tcl command to blocks with minimum period or minimum pulse width limits, Spectra-Q TimeQuest might apply the timing deration to your design incorrectly.
This issue affects the Quartus® Prime Standard Edition software and the Quartus Prime Pro Edition software.
Resolution
Run Spectra-Q Timing Analyzer with the force_dat option:
  • Run quartus_sta -force_dat from the command line.
  • Run create_timing_netlist -force_dat from the Spectra-Q TimeQuest GUI.
Updated 2 months ago
Version 2.0
