Knowledge Base Article
SOPC Builder Does Not Recognize Decimal Points
Description
If you assign the PLL clock with a value with decimals, SOPC
Builder takes only the whole number and does not recognize the value
after the decimal point. When you generate the system, the The
PLL reference clock of <value> does
not match the clock frequency input to refclk error message
appears.
This issue affects all designs that have a PLL clock value with decimals.
Your system cannot be generated.
Resolution
Ignore the error message, and generate the system by holding down the Ctrl key on the keyboard while clicking Generate in SOPC Builder.
This issue will be fixed in a future version of the DDR and DDR2 SDRAM Controllers with ALTMEMPHY IP.
Updated 2 months ago
