Knowledge Base Article
Some RapidIO IP Core Variations Might Execute Two Maintenance Writes in Response to One Received Maintenance Write Request
Description
RapidIO IP core 1x variations with a 16-bit device ID do not handle MAINTENANCE write requests correctly if the request has mnt_m_address[2] set to the value of 1. In this case, the RapidIO IP core executes two MAINTENANCE write requests instead of one.
Resolution
This issue has no workaround.
This issue is fixed in version 14.1 of the RapidIO IP core.
Updated 2 months ago
Version 2.0
