Knowledge Base Article
Some RapidIO II IP Core Port 0 Capture CSRs Do Not Update Correctly
Description
The RapidIO II IP core Port 0 Attributes Capture CSR (offset
0x348) and Port 0 Packet/Control Symbol Captures CSRs
(offsets 0x34C, 0x350, 0x354, and 0x358) do not update correctly.
As of the RapidIO II IP core version 14.0, this issue is fixed with the exception of back to back control symbols. In the case of back to back control symbols only, the RapidIO II IP core does not update these registers correctly. However, in all other cases, the RapidIO II IP core now updates these registers correctly.
Resolution
This issue has no workaround.
This issue will be fixed for back to back control symbols in a future version of the RapidIO II MegaCore function.
Updated 1 month ago
