Knowledge Base Article
Some RapidIO II IP Core Capture Registers Do Not Update Correctly From User Logic
Description
The Logical/Transport Layer Control Capture CSR (offset 0x31C) FTYPE and TTYPE fields and the Logical/Transport Layer Device ID Capture CSR (offset 0x318) fields should update with the values that user logic writes with the following input signals:
external_capture_destinationID_wr
external_capture_destinationID_in
external_capture_sourceID_wr
external_capture_sourceID_in
external_capture_ftype_wr
external_capture_ftype_in
external_capture_ttype_wr
external_capture_ttype_in
However, the register fields do not update as expected.
Resolution
This issue has no workaround.
This issue is fixed in version 14.0 of the RapidIO II MegaCore function.
Updated 1 month ago
Version 2.0
