Knowledge Base Article
Some Low Latency 40-100GbE IP Core Status Registers Are Not Readable
Description
The following LL 40-100GbE IP core TX statistics and RX statistics status registers are not correctly readable in the IP core v14.1:
TXSTAT_REVIDat offset 0x840TXSTAT_SCRATCHat offset 0x841TXSTAT_NAME_0,TXSTAT_NAME_1, andTXSTAT_NAME_2at offsets 0x842-0x844CNTR_TX_CONFIGat offset 0x845CNTR_TX_STATUSat offset 0x846RXSTAT_REVIDat offset 0x940RXSTAT_SCRATCHat offset 0x941RXSTAT_NAME_0,RXSTAT_NAME_1, andRXSTAT_NAME_2at offsets 0x942-0x944CNTR_RX_CONFIGat offset 0x945CNTR_RX_STATUSat offset 0x946
Resolution
This issue has no workaround. Do not rely on the values you read from these registers.
This issue is fixed in version 15.1 of the Low Latency 40- and 100-Gbps Ethernet MAC and PHY IP core.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
