Knowledge Base Article
Some High-Speed Ethernet IP Core User Guides Do Not Clarify Lack of Support for VHDL
Description
The user guides for the following IP cores do not clarify that the IP cores do not support VHDL models:
  • Low Latency 40-Gbps Ethernet IP core
  • Low Latency 100-Gbps Ethernet IP core
  • 25G Ethernet IP core
The parameter editors for these IP cores appear to offer the option to select VHDL simulation and synthesis models.  Therefore, the user guide should clarify that these models are not actually available. In addition, the user guide should clarify that the VHDL-specific files the Quartus® Prime software generates with the IP core are not functional.
Resolution
In the IP core parameter editor, ensure you select Verilog HDL for the models you wish to generate. Be aware that .vhd and other VHDL-specific files listed in the user guide are not functional.
Updated 1 month ago
Version 2.0
