Knowledge Base Article
Some CPRI IP Core Variations Configured with the Advanced 1 Mapping Mode Might Not Achieve Timing Closure
Description
If your CPRI IP core variation is configured with Mapping mode set to Advanced 1, and the target device family and CPRI line rate are set to any of the following combinations, your CPRI IP core may fail to achieve timing closure.
Timing closure failure has been observed in the following combinations of target device family and CPRI line rate:
  • Arria V device at CPRI line rate 6.144 Gbps
  • Stratix V device at CPRI line rate 9.8304 Gbps
Resolution
This issue has no workaround.
This issue is fixed in version 12.1 of the CPRI MegaCore function.
Updated 2 months ago
Version 2.0
