Knowledge Base Article
Some 100G Interlaken IP Core Parameter Settings Cause Arria 10 Timing Issues
Description
If your 100G Interlaken IP core instance targets an Arria 10 device, and you turn on either of these two parameters in the 100G Interlaken parameter editor, your IP core might not achieve timing closure in compilation.
  • Include advanced error reporting and handling
  • Enable M20K ECC support
Resolution
This issue has no workaround. To avoid timing issues in the 14.0 Arria 10 Edition version of this IP core, you should turn off these two parameters.
This issue is fixed in version 14.1 of the 100G Interlaken IP core.
Updated 2 months ago
Version 2.0
