Knowledge Base Article
SoC Embedded Design Suite User Guide Does Not Describe All Required BSP Generation Arguments
Description
In the Altera SoC Embedded Design Suite User Guide, the following command-line tools are documented improperly:
bsp-create-settingsbsp-update-settings
For bsp-create-settings, the user guide states
that the parameter --preloader-settings-dir is optional;
but it is required. Also for bsp-update-settings,
it states that --preloader-settings-dir is a valid
parameter; but it is not. Using the parameters as documented will
cause a build error.
Resolution
The workaround for bsp-create-settings is to
use the following required parameters:
--type--settings--preloader-settings-dir
and the following optional parameters:
--bsp-dir--set
The workaround for bsp-update-settings is to
use the following required parameter:
--settings
--bsp-dir--set
Do not use --preloader-settings-dir with bsp-update-settings.
Updated 3 months ago
