Knowledge Base Article
SmartVID Controller IP Core Designs Targeting Arria 10 10AX115 Devices Fail Timing
Description
The SmartVID Controller IP core designs targeting Arria 10 10AX115 devices experience hold time violation for the following path :
from
altera_parallel_smartvid_wrapper:i_altera_parallel_smartvid_wrapper|altera_vid_ctl_wrapper:altera_vid_ip|altera_vid_ctl_fuse:fuse_handling|corectl_jtag_reg
to
altera_parallel_smartvid_wrapper:i_altera_parallel_smartvid_wrapper|jtag~cs_css/tck_fo_1_core.reg__nff.
This issue will cause timing failure.
This issue affects all designs using the SmartVID Controller IP core versions 14.1 and 14.1 Arria 10 Edition.
Resolution
Set this path to false path.
Updated 1 month ago
Version 2.0
