Knowledge Base Article
Simulation With Riviera-PRO May Fail to Initialize Under Certain Conditions
Description
This problem affects all external memory interface products.
If your design uses a VHDL simulation model with an Altera External Memory bus functional model (.BFM), simulation with a version of Riviera-PRO earlier than 2014.02 may fail with the following error:
VSIM: Error: Simulation initialization failed
Resolution
The workaround for this issue is to use Riviera-PRO version 2014.02 or later.
Updated 1 month ago
Version 2.0
