Knowledge Base Article
Simulation Runs Infinitely When Using The SDI II MegaCore Design Testbench
Description
When you simulate the generated SDI II MegaCore design example, the simulation runs infinitely. The simulation testbench fails if you set the following features of the SDI II MegaCore to create the design example:
Select Triple Standard for the Video Standard option
Turn on the Tx PLL Dynamic Switching option
Turn on the Increse Error Tolerance Level option
This issue affects the SDI II MegaCore in Quartus II software version 13.0SP1.
Resolution
None.
This issue will be fixed in Quartus II software version 13.1.
Updated 1 month ago
