Knowledge Base Article
Simulation of 10GBASE-R, Custom, Interlaken, Low Latency, PCI Express PIPE, and XAUI Transceiver PHY IP Cores Fails for Stratix V if You Use ModelSim With Mixed Languages
Description
Simulation of 10GBASE-R, Custom, Interlaken, Low Latency, PCI Express PIPE, and XAUI Transceiver PHY IP cores for Stratix V devices fails if you use ModelSim with mixed languages.
Resolution
Turn off ModelSim optimization with the -novpt option
of the vsim command..
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
