Knowledge Base Article
Simulation Fails for UniPHY External Memory Interfaces when Generating VHDL for Designs Using Nios II-based Sequencer
Description
For designs using the Nios II-based sequencer, simulation can fail when generating VHDL output.
Resolution
The workaround for this issue requires that you manually modify certain files:
- Look for three .vhd files with
file names beginning with a string similar to the following:
dut_dut_e0_if0_p0_qsys_sequencer_cpu_inst_jtag_debug_modulewhere <dut> is the name that you have specified for your project. - Open each of the three files in a text editor and add
the following two lines to the beginning of each file:
library altera_mf; use altera_mf.altera_mf_components.all;
Updated 2 months ago
