Knowledge Base Article
Simulation Error QDR II and QDR II SRAM Controller with UniPHY
Description
Inconsistency between module definition and instantiation may cause some simulators to produce an error message.
Resolution
The workaround for this issue is to manually edit the oct_control.v and clock_pair_generator_config.v files, and remove specific port names from each, as described below.
Port Names to Remove from clock_pair_generator_config.v
File:
<variation_name>/rtl/<variation_name>_clock_pair_generator_config.v
Module:
arriaii_pseudo_diff_out
Instance:
pseudo_diffa_0
Port names to remove:
.dtc� .dtcbar� .oebout� .oeout� .dtcin� .oein
Port Names to Remove from oct_control.v
File:
<variation_name>/rtl/<variation_name>_oct_control.v
Module:
arriaii_termination_logic
Instance:
sd2a_0
.scanout� .s2pload� .scanclk� .scanenable� .scanin� .serdata
Updated 3 months ago
Version 2.0
