Knowledge Base Article
Should I insert a memory barrier instruction before issuing DMASEV to CPU?
Description
The recommendation from ARM and Altera is to insert a memory barrier instruction before issuing DMASEV instruction to CPU to avoid DMA controller signaling an interrupt before AXI transfers is completed.
Resolution
The HWlibs DMA driver alt_dma.c is being updated with a Memory Barrier Instruction added before DMASEV instruction as shown below.
if (send_evt)
if (status == ALT_E_SUCCESS)
status = alt_dma_program_DMAWMB(program);
dprintf("DMA[M->M]: Adding event ...\n");
status = alt_dma_program_DMASEV(program, evt);
The updated version of the HWlibs DMA driver is scheduled to be available in the next release of SoC EDS.
Updated 2 months ago
