Knowledge Base Article
SEVERE: elf2flash: Read error: File not found: /mnt/c/intelFPGA_pro/19.2/nios2eds/components/altera_nios2/boot_loader_cfi.srec
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.2, you may see below errors when doing "make_init_generate" in Nios® II Software Build Tools for Eclipse for a needed hex file generation:
Post-processing to create mem_init/generic_quad_spi_controller2_0.hex...
alt-file-convert.exe -I elf32-littlenios2 -O hex --input=test01.elf --output=mem_init/generic_quad_spi_controller2_0.hex --base=0x02000000 --end=0x03ffffff --reset=0x02500000 --out-data-width=8 --boot="/mnt/c/intelFPGA_pro/19.2/nios2eds/components/altera_nios2/boot_loader_cfi.srec"
?? 26, 2020 2:08:33 ?? com.altera.commandApplication.CmdApp severe
SEVERE: elf2flash: Error reading boot copier
SEVERE: elf2flash: Error generating Flash file, exiting
Picked up _JAVA_OPTIONS: -Djava.net.preferIPv4Stack=truenios2-elf-objcopy: 'C:\Users\anchen\AppData\Local\Temp\tmp85ntu6x2': No such file
Converting Nios II ELF file to HEX file. Appending boot file.
Resolution
To work around this problem, follow the steps below:
1.Please copy boot_loader_cfi.srec from installation path and place it in your NiosII software project folder.
2.Mannully run above alt-file-convert.exe command from NiosII Command Shell, the needed hex file will be generated successfully.
This problem is fixed starting with the Intel Quartus Prime Pro Edition software version 20.1.
Updated 21 days ago
Version 2.0
