Knowledge Base Article
SerialLite III Streaming IP Core with ECC Enabled Mode has Incorrect ECC Bits Assigned in tx_error Port
Description
For Stratix V, Arria V GZ, and Arria 10 SerialLite III Streaming IP Core with ECC
enabled mode, the ECC error status bits are incorrectly assigned in the tx_error
port (tx_error[2:1]), where tx_error[1] is assigned with
ECC fatal error, and tx_error[2] is assigned with ECC correctable
error.
The correct assignment should be tx_error[1]: ECC correctable
error.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future release.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
