Knowledge Base Article
SerialLite III Streaming 14.1 Arria 10 Example Design Cannot Compile
Description
The SerialLite III Streaming example design for variations that target an Arria 10 device cannot compile in the Quartus II software v14.1.
When you open the Arria 10 example design project, IP Upgrade prompts you to upgrade the IP core. However, after you do so the software generates errors.
Resolution
This issue has no workaround.
This issue will be fixed in a future version of the SerialLite III Streaming IP core.
Updated 1 month ago
Version 2.0
