Knowledge Base Article
Serial Digital Interface Library Not Generating Transceiver Modules when Directory Name Contains Spacing
Description
The custom PHY modules for the serial digital interface (SDI) does not generate transceiver modules when the users IP directory name contains spacing.
This issue occurs in both Windows and Linux platforms, and affects the Arria V, Arria V GZ, Stratix V and Cyclone V devices using custom PHY from version 12.0 onwards.
Resolution
Do not use spacing for the directory name.
This issue may not be fixed.
Updated 2 months ago
