Knowledge Base Article
Serial Digital Interface II MegaCore Design Setup Time Violation
Description
If you enable any SDI II feature that requires the transceiver reconfiguration controller, such as setting the video standard to Dual Standard or Triple Standard, or enabling the Tx PLL Dynamic Switching option, the SDI II MegaCore design may not meet the setup time. This is because multiple channels that share the same reconfiguration controller are placed at two different sides of the device.
This issue affects the SDI II MegaCore in Quartus II software version 13.0.
Resolution
You need to manually assign the location for each channel to be at the same side of the device or at locations that are close together.
This issue will be fixed in Quartus II software version 13.1.
Updated 2 months ago
Version 2.0
