Knowledge Base Article
Serial Digital Interface I Design Long Locking Time in 40nm Devices
Description
The Serial Digital Interface (SDI) I design has long locking time when switching from high definition (HD) to third-generation (3G) or when the core is reset after receiving 3G.
The design takes a longer time to achieve frame lock when the rate detection block cannot detect the standard correctly because the data recovered during the rate detection is incorrect.
This issue affects the SDI I design in 40nm devices.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future version.
Updated 1 month ago
Version 2.0
