Knowledge Base Article
Segmentation Fault When Registering GPIO Interrupt Handler
Description
In the Linux implementation included with the Golden System Reference Design, if you attempt to register an interrupt handler for a nonexistent GPIO device, you will see error messages similar to the following:
Unable to handle kernel NULL pointer dereference at virtual
address 00000028
Segmentation fault
These errors indicate a kernel segmentation fault.
Resolution
With the Golden System Reference Design, ensure that you attempt to register interrupts only for existing GPIO devices.
Alternatively, upgrade to v13.1 or later.
Updated 2 months ago
