Knowledge Base Article
Segmentation Fault During Elaboration with ModelSim SE
Description
If you run the ld or elab commands
in the msim_setup.tcl script for a UniPHY-based IP
core in ModelSim SE, you may encounter a segmentation fault during
elaboration.
This issue applies to all UniPHY-based external memory interface IP cores when using ModelSim SE; this behaviour does not occur with ModelSim AE.
Resolution
The workaround for this issue is to use the ld_debug or elab_debug commands
as provided in the msim_setup.tcl script, or to add
the -novopt option to the vsim command
in the script.
Updated 2 months ago
