Knowledge Base Article
SDI RX Asserts Active Picture Interval Timing Signal Earlier When Receiving 3G-SDI Level B Video Data
Description
SDI RX asserts the active picture interval timing (rx_ap) signal one
clock cycle earlier. The first data received when the rx_ap signal
asserts is not an active picture data. However, the data that come after that are
all valid until the rx_ap signal deasserts. If you are relying on the
rx_ap signal to process your video data, the data produced on the
first cycle will be incorrect.
Resolution
There is no workaround for this issue.
This issue will be fixed in a future version of the SDI IP core.
Updated 1 month ago
