Knowledge Base Article
SDI II IP Core rx_video_format Signal Shows Wrong Encoding Format
Description
When the Serial Digital Interface (SDI) II IP core receives video data with RGB / YCbCr 4:4:4 mapping structure, the rx_video_format signal shows 0xFF instead of the correct encoding of the video format.
This issue affects 4:4:4 mapping structures in 3G Level A standards. The user logic that are relying on the rx_video_format signal may not function correctly.
This issue is fixed in version 14.1 of the SDI II IP core.
Updated 3 months ago
