Knowledge Base Article
Scaler II Generates Incorrect Output When Vertical Filter Taps is 3
Description
The Scaler II MegaCore function using polyphase algorithm may generate incorrect output when you set Vertical Filter Taps to 3.
This issue affects all configurations that use the polyphase algorithms with the Scaler II MegaCore function.
The affected configuration may generate incorrect output.
Resolution
None available. If your design allows, set Vertical Filter Taps to 4.
This issue will be fixed in a future version of the Video and Image Processing Suite.
Updated 1 month ago
Version 2.0
