Knowledge Base Article
Scaler II Generates Incorrect Output When It Receives Elongated Control Packet
Description
The Scaler II MegaCore function with the Enable run-time control of input/output frame size option turned on may generate incorrect output when it receives an elongated control packet.
This issue affects your system if you instantiate the Scaler II Megacore function directly after you instantiate the Color Plane Sequencer or Chroma Resampler Megacore function.
The affected configuration may generate incorrect output or crash.
Resolution
None. Avoid using the Scaler II MegaCore function with the Enable run-time control of input/output frame size option turned on directly after the Color Plane Sequencer or Chroma Resampler Megacore function.
This issue is fixed in version 11.0 of the Video and Image Processing Suite.
Updated 2 months ago
