Knowledge Base Article
Running the create_timing_netlist Command with an Uncommon Operating Condition Results in Empty Spectra-Q TimeQuest Timing Reports or Internal Errors
Description
For Arria® 10 designs, running the
create_timing_netlist command with an explicit operating condition
that is not typically analyzed by Spectra-Q™ TimeQuest
results in empty timing reports or internal errors.
This issue affects the Quartus® Prime Standard Edition software and the Quartus Prime Pro Edition software.
Resolution
- Run the
create_timing_netlistcommand without specifying an operating condition. - Run the
set_operating_condition <operating_conditions>command to switch to the desired operating condition.
Updated 3 months ago
