Knowledge Base Article
Running the <variation name>_pin_assignments.tcl file from the Tcl Scripts dialog box fails to apply pin assignments in UniPHY-based IP
Description
In UniPHY-based IP, if you attempt to run the <variation name>_pin_assignments.tcl file from the Tcl Scripts dialog box, the file fails to apply pin assignments.
Resolution
To run the <variation name>_pin_assignments.tcl file, type the following command in the Tcl Console:
source <path to file>/<variation name>_pin_assignments.tcl
For example:
D:/MyQDR/constraints/qdr_pin_assignments.tcl
Updated 2 months ago
