Knowledge Base Article
Run-time error '53': File not found
Description
You may see this runtime error when opening the Early Power Estimator (EPE) tool.
This is because EPE extracts its DLLs and data to the system %TEMP% folder when it's opened. Sometimes, one of these files may become corrupt and cause an error in the title.
Resolution
To fix this error, follow the instructions below:
- Close all Excel processes (including EPE).
- Go into Windows Explorer (File explorer)
- Type %TEMP%\EPE_Tool into the address bar
- Remove everything in this directory.
- Try opening EPE again.
Updated 1 month ago
