Knowledge Base Article
Run Configuration Cannot Find Imported Custom Makefile Project
Description
After you import a project using the Import Custom Makefile for Nios II Software Build Tools Project option, the Nios II SBT fails to recognize the imported custom makefile as a Nios II C/C application project. As a result, the project name does not appear in the list in the run configuration.
Resolution
In the Run Configuration dialog box, select any visible Nios II C/C project. The project need not be related to your custom makefile project. Note: If there is no Nios II C/C project in your workspace, create a dummy project, such as Hello World, through the File menu, by clicking New, Nios II Application and BSP from Template.
Turn on Enable browse for file system ELF file.
Browse to the correct .elf file for your custom makefile project to complete creation of a run configuration.
Alternatively, install the Altera Complete Design Suite version 10.1 or later.
Updated 2 months ago
