Knowledge Base Article
Rule C103: Gated clock does not feed at least a pre-defined number of clock ports to effectively save power
Description
You may see the following warning when running the Design Assistant tool in Quartus II software on your compiled HPS design.
Rule C103: Gated clock does not feed at least a pre-defined number of clock ports to effectively save power ; <hierarchy>:altdq_dqs2_inst|dqsbusout
Resolution
This warning is expected and can be safely ignored.
Updated 2 months ago
Version 3.0
