Knowledge Base Article
Rule C101: Gated clock should be implemented according to the Altera standard scheme
Description
You may see the following warning when running the Design Assistant tool in Quartus® II software on your compiled HPS design.
Rule C101: Gated clock should be implemented according to the Altera standard scheme ; <hierarchy>:altdq_dqs2_inst|dqsbusout
Resolution
This warning is expected and can be safely ignored.
Updated 1 month ago
