Knowledge Base Article
RTL Simulation Reports Errors When Using Verilog HDL
Description
EDA RTL simulation started from the Quartus II software reports errors in the ModelSim® simulator for designs containing Video and Image Processing Suite MegaCore functions when the output files are in Verilog HDL.
This issue affects configurations that use NativeLink to run a ModelSim simulation from Verilog HDL.
An error message reports that software cannot find the Altera library.
Resolution
Compile the file db/alt_cusp90_package.vhd to the Altera library. To perform this compilation, modify the top-level .do script in the simulation/modelsim directory.
This issue will be fixed in a future version of the Video and Image Processing Suite.
Updated 11 months ago
Version 3.0
