Knowledge Base Article
Riviera* Simulation Errors of the Stratix® 10 Avalon® Streaming and Single Root I/O Virtualization (SRIOV) Interface for PCI Express* Solutions IP.
Description
Due to a problem wih the ALDEC* Riviera* simulation tool, the following or similar error will be seen when simulating the Stratix® 10 Avalon® Streaming and Single Root I/O Virtualization (SRIOV) Interface for PCI Express* Solutions IP.
ALOG: Error: VCP2950 SEG_WIDTH*2 is not a valid right-side of defparam.
Resolution
No workaround is available when using the ALDEC* Riviera* simulation tool. This problem is not seen with other supported simulators.
This problem has been reported to ALDEC*.
Updated 3 months ago
