Knowledge Base Article
Recovered Clock Not Supported for Arria V GT Designs
Description
This errata affects the Triple-Speed MegaCore function.
The MegaCore function does not support recovered clock for designs that target Arria V GT devices. The Quartus II software fails to fit and merge the transceivers when the rx_recovclkout clock is connected to an output pin.
This issue affects all design that target Arria V GT devices.
Resolution
Manually assign the transceiver channels away from the bottom-most triplet for designs targeting Arria V GT devices.This issue will be fixed in a future version of the Triple-Speed Ethernet MegaCore function.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
