Knowledge Base Article
Reconfiguration of a clock multiplier unit (CMU) PLL in an ALTGX megafunction might fail for Stratix IV GX
Description
In an ALTGX megafunction, reconfiguration of a clock multiplier unit (CMU) PLL might fail if the CMU PLL drives a transmitter channel using a central clock divider through X4/XN and either
  • The transceiver channel is in bonded mode configuration, or
  • The Use central clock divider to drive the transmitter channels using X4/XN lines option on the Main PLL page of the Reconfiguration Settings tab is on.
Resolution
Set location assignments to place the CMU PLL that drives a transceiver channel using a central clock divider at location CMU0 PLL.
Updated 3 months ago
Version 2.0
